Switching between schematic and lay-out annoyingly slow
pascal0312
pascal0312
Used to Eagle for a few years now and since Eagle is getting no/less updates and the focus shifts to Fusion for Electronics Design I at least want to try it out for 1 project. I've got some issues though.
The switching between schematic and layout view is very slow. It seems to close the schematic view altogether, closing the icons, taskbar, schematic view, design manager, inspector. Then opening the layout view, opening the taskbar, inspector, ..., etc. If it's in two tabs I expect it to work almost instantaneously. I've got a beefy laptop, Dell XPS, and it feels like it's closing and opening a new Fusion instance.
I know about the 'chrome tab' you can drag out, but I'm missing the different 'chrome tab features'. I can drag out, but not in. I also can't rearrange the tabs. And, like the first issue, it's still slow. Closing the one instance, opening the other instance. I can visually see what parts of the program are shutting down.
Can this be fixed/added? It seems like Fusion is running three time as heavy as Eagle did.
Thank you.
yqliu
Hello @pascal0312 ,
It's a known issue that the switching between schematic and layout view is slow. The team is trying to fix it.
Regarding to the tabs, once you drag a tab out, you can see there is an arrow icon on the right side of the tab. If you click it, you will put the tab back to the main window.
j.lodder
Any luck fixing this yet? It takes about 4 seconds, which is a very bad first impression.
jstrautman
I will second the call for an answer on a fix for this.  It is not only annoying, but causing loss in productivity time.  Especially if you want to use one screen only so you can have a datasheet or something on the other screen.  We looked into graphics cards in our PC's thinking that may be the issue, but def is not that and must be something within the Fusion system causing it.
james_baberSEFAT
Will this ever be improved? 5 years later and nothing has changed.
I was promised a fix by support "An improvement planned for commercial release has been released in Fusion Insider version" but I don't think it will ever come.
@yqliu
jorge_garcia
Hello @james_baberSEFAT,
Through out the years we've actually been releasing multiple improvements for this tab switching delay. It's much better than it once was but it might still not be good enough.
Does it happen for you specifically when switching between schematic and board? Is it with a specific design or operation? What amount of delay are you seeing?
Any and all info will help us look for other places in the code where performance can be improved.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
