Standoff library, throwing errors, need improvement?
sylvain_boyer6TGNB
sylvain_boyer6TGNB
I have placed some standoff from the official library PCB-fastener_hardware.
I left the standoff unconnected in my schematic. After placing them on the PCB, there are 3 errors per standoff that are thrown. I suspect these are directly subject to the design rules and how the cutouts are modelled with the standoff.
Is there a way to specify exceptions based on components (rather than clearing the error manually)?
frijo.francis0912
Thank you @sylvain_boyer6TGNB bringing this to our attention. There is a hole on top of the plated though-hole pad in all of the devices in the standoff libraries. We will investigate and make necessary changes in the library to avoid the situation. But for now, what you can do is create a copy of the standoff library and delete the hole on top of the mounting pad manually or you can even create your own library. I have attached an example library that you can use as a template
Frijo Francis
Fusion 360 Product Support
