Some 3d models are not appearing when i push to create the PCB
jorge_orta8GUV6
Message 1 of 10
jorge_orta8GUV6
So some 3d models are in the library but for some reason they dont appear on the 3d pcb ?
why is that happening?
Replies (9)
Message 2 of 10
jorge_garcia
Hi @jorge_orta8GUV6,
I hope you're doing well. Is this your personal library or a company library? Where did you get the 3D models from? Are you sure that you have updated the design to use the latest version of the library?
The more information you can provide the easier it will be to figure out what's going on.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 3 of 10
jorge_orta8GUV6
Some components are from a library of an organization I work for they shared with me. Some of those components they do render.
I guess is not finding the library is there a way to map all of this components with the missing library to the correct one that is already loaded?
Message 4 of 10
Taylor.Chris
Hey @jorge_orta8GUV6 ,
Fusion has made a change where now designs are not allowed to reference libraries that live in another Team, I suspect that is the issue here.  You will need to get the library and its packages moved into the correct team.  The easiest way to do this is to push the library to library.io, then you can edit it from the second team and it will copy the library.
Message 5 of 10
Taylor.Chris
We will be making a public post with more information on this soon, the change caught us by surprise.
Message 6 of 10
jorge_orta8GUV6
My workflow was..
Client sent me his eagle files to modify.
I imported them into fusion electronics. they shared the  library  from library.io.
for some reason fusion made a local copy in my dev pc from their library.
when i click swap libraries, it does not detect any changes
I am not understanding the purpose of linked libraries. if they share a library i should be able to build on top.. no build on the LINKED.
right now the only solution i have found is to replace component by component with the component from the linked library which is very inefficient.
Message 7 of 10
Taylor.Chris
From that screenshot I believe that you should be able to swap those libraries.  What is the tooltip saying when you hover over the swap button?
Message 8 of 10
jorge_orta8GUV6
Swap button is grayed out
Message 9 of 10
Taylor.Chris
Have you updated to the May release?  This restriction should have been removed in May.
Message 10 of 10
jorge_orta8GUV6
yes it was that.. is working know
