I have an electronic design. It's a wonderful design, and all the parts are there - what I guess is called a 'design file', a schematic, a 2D PCB layout and a 3D board. I completed it months ago, and it's been sitting and just waiting for me to pipe it to a CNC machine and cut it out.
But I wanted to put the ~3x5" PCB into a panel, so I could cut multiple boards out of a 12x12" blank. (Wasting FR4 causes global warming or something, probably.) Turns out, this is its own special little nightmare, but that's not what I'm here about. This time.
Like a good little designer, I made sure to 'save as' and make copies of all my files in a totally separate and distinct folder before I did anything related to panelize.ulp. And it's a good thing I did. You see, something went wrong with the panelization of the board, and it not only eliminated both copper pours (ground planes) on the top and bottom of the board, but somehow, through processes I do not understand, the dutifully named ORIGINAL and COPY versions of this design have become intermingled.
So, now, when I open the ORIGINAL version of the design file, it throws warnings because there are newer versions of the schematic, the 2D PCB, and the 3D board. Even though I've deleted all the files I labeled as COPY. Unless I open the broken versions of everything, it all becomes read-only, and any amount of 'save as' just becomes an infinite loop of copy-making because there's a 'newer version,' even though the one I just saved seconds ago should be the newest version of all.
So, the big question: How do I get my original work back to a usable state? How do I re-link the design file to the schematic I want, the 2D layout I want, and the 3d board that I want, and discard the others?
Second almost-as-big question: How do I actually panelize my PCB so that I can get multiples out of a 12x12" slab of FR4? I followed the links that this fine chap was kind enough to send me, but after trying panelize.ulp, I'm a little afraid of the 2nd one,
Third, nowhere-near-as-big question, but would be nice to know: Why is this like this? It seems as though F360 has broken many long-standing standards for both file management and/or version control for the sake of... something? Is it going to stay like this? Or is it one of those things that "someone" is "working on"?
Thanks in advance.
