Simple schematic question
Etbrown44
Etbrown44
Community Visitor
Community Visitor
I've connected this simple time delay relay before, but need a tip this time as I'm not getting output.
I have 110v supplied to A1 and A2. I read nothing on 15,16 or 18, even after time delay has passed. It is a "delay on" relay.
I have 2 of these relays. One new. Both unlikely to be defective, so has to be operator error!
Suggestions most welcome.
paullevene
You’re almost there, the trick on this model is that it needs a separate control input (S) to start the timing. Powering A1–A2 alone won’t make the relay change state, and the terminals 15/16/18 are just a dry change-over contact (no voltage appears there unless you feed one in).
Quick bench test / wiring
  1. Supply: L → A1, N → A2 (110 VAC).
  2. Trigger: Link A1 to S (ideally through a switch). This applies the control signal that starts the “delay-on” timing.
  3. Output: Feed the voltage you want to switch into 15 (e.g., L).
    • At rest you should have continuity 15–18 (NC) and open 15–16 (NO).
    • After S is energised and the set delay expires, the relay clicks and you get continuity 15–16 (and L will appear on 16 if you fed L into 15).
If you don’t hear a click:
  • Make sure the function is set to delay-on and the time range isn’t set to hours (set the shortest range and a small time first).
  • Verify you actually have ~110 VAC across A1–A2.
  • Try momentarily removing and re-applying S to give it a clear rising edge.
Safety note: 110 VAC can bite—double-check isolation before probing.
Do the above and you should see the output behave.
Etbrown44
Community Visitor
Community Visitor
I was just asking if this relay provided a 110v output, and I see it just makes or breaks an isolated contact. Never needed S, as we just put 110v to a1 and a2.
