Silk Screen and Tracking Data Missing from PCB Assembly drawings & STEP/IGES Outputs
Michael_Dalby6FK4J
Michael_Dalby6FK4J
Hi All,
I have seen a few people asking this question previously and a fix was promised -  has the issue ever been fixed?
Some of the posts date back to 2019... In this Post @jorge_garcia suggest that a fix was on the way:  Solved: Re: STEP export does not export copper or silkscreen - Autodesk Community - EAGLE.
I have just tried it and it still seems to be an issue - which is bad for something that was promised 5 years ago.
This is the issue:
I see the silkscreen and track detail in the 3D view, but If I try to make a drawing from the 3D model (which has the silk screen present).....
..the output assembly drawing loses all of the track and silkscreen data:
This is also the same if I export the assembly as a step of IGES model - no Silk screen or track data .
Am I doing something wrong or has this not been fixed yet ?
Cheers, Michael
jorge_garcia
Hi @Michael_Dalby6FK4J ,
I hope you're doing well. I've answered your question on the other post you made.
https://forums.autodesk.com/t5/eagle-forum/step-export-does-not-export-copper-or-silkscreen/m-p/1289...
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
