Hi Jorge,
Thanks for your reply.
Let's compare the length for one signal trace on the PCB, M_A0. Here is data exported by the length-freq-ri ULP, showing data for the M_A0 trace:
EAGLE Version 9.7.0 Copyright (c) 1988-2023 Autodesk, Inc. | | | | | | |
List of signals with length and its max. frequency / current | | | | | | |
exported from C:/Users/gembl/AppData/Local/Temp/Neutron/ElectronFileOutput/26376/brd-45b6210a-145e-49af-9266-ddeb05093221/EpiBack.brd | |
at 11/20/2023 10:21 PM | | | | | | | |
Signal | f max. [MHz] | l [mm] | A [mm2] | R [mOhm] | w min [mm] | w max [mm] | Imax [A] |
GND | 241.48 | 1241.533 | 0.002 | 12149.98 | 0.051 | 1.016 | 0.19 |
M_A0 | 3810.95 | 78.668 | 0.004 | 384.93 | 0.102 | 0.127 | 0.35 |
Here is data from the SI Extension:
Signal Path | Length | Impedance | Time Delay | Resistance | Capacitance | Inductance |
M_A0 11/14/2023 16:14 - 1.00GHz, Target Z0 50 Ohm +/- 10 % | | | | |
Path-U2(P3)-U1(AK25) | 1417.44 mil | 40.58 - 128.42 Ohm | 255.78 ps | 2283.82 mOhm | 0.00 - 3.32 pF | 11.81 nH |
Seg-1 | 13.27 mil | 52.07 Ohm | 1.98 ps | 14.52 mOhm | 0.038 pF | 0.10 nH |
Seg-2 | 5.27 mil | 116.37 Ohm | 0.63 ps | 4.58 mOhm | 0.005 pF | 0.07 nH |
Seg-3 | 0.41 mil | 76.21 Ohm | 0.06 ps | 0.39 mOhm | 0.001 pF | 0.00 nH |
Seg-4 | 3.31 mil | 76.21 Ohm | 0.45 ps | 3.11 mOhm | 0.006 pF | 0.03 nH |
Seg-5 | 3.31 mil | 62.58 Ohm | 0.60 ps | 4.07 mOhm | 0.010 pF | 0.04 nH |
Seg-6 | 0.41 mil | 62.58 Ohm | 0.08 ps | 0.51 mOhm | 0.001 pF | 0.00 nH |
Seg-7 | 5.27 mil | 128.42 Ohm | 0.82 ps | 5.77 mOhm | 0.006 pF | 0.11 nH |
Seg-8 | 204.88 mil | 43.30 Ohm | 37.27 ps | 264.19 mOhm | 0.861 pF | 1.61 nH |
Seg-9 | 5.27 mil | 128.42 Ohm | 0.82 ps | 5.77 mOhm | 0.006 pF | 0.11 nH |
Seg-10 | 3.73 mil | 62.58 Ohm | 0.68 ps | 4.58 mOhm | 0.011 pF | 0.04 nH |
Seg-11 | 2.70 mil | 69.87 Ohm | 0.48 ps | 4.29 mOhm | 0.007 pF | 0.03 nH |
Seg-12 | 1.02 mil | 69.87 Ohm | 0.18 ps | 1.62 mOhm | 0.003 pF | 0.01 nH |
Seg-13 | 5.27 mil | 127.18 Ohm | 0.78 ps | 7.81 mOhm | 0.006 pF | 0.10 nH |
Seg-14 | 111.94 mil | 45.32 Ohm | 20.42 ps | 195.68 mOhm | 0.451 pF | 0.93 nH |
Seg-15 | 188.72 mil | 40.58 Ohm | 34.40 ps | 280.88 mOhm | 0.848 pF | 1.40 nH |
Seg-16 | 825.90 mil | 45.32 Ohm | 150.66 ps | 1443.74 mOhm | 3.324 pF | 6.83 nH |
Seg-17 | 5.27 mil | 93.76 Ohm | 0.89 ps | 7.83 mOhm | 0.010 pF | 0.08 nH |
Seg-18 | 3.73 mil | 69.85 Ohm | 0.66 ps | 5.86 mOhm | 0.009 pF | 0.05 nH |
Seg-19 | 3.64 mil | 76.21 Ohm | 0.49 ps | 3.42 mOhm | 0.006 pF | 0.04 nH |
Seg-20 | 5.27 mil | 116.37 Ohm | 0.63 ps | 4.58 mOhm | 0.005 pF | 0.07 nH |
Seg-21 | 18.84 mil | 52.07 Ohm | 2.80 ps | 20.61 mOhm | 0.054 pF | 0.15 nH |
Path-U2(P3)-U3(P3) | 469.74 mil | 43.30 - 128.42 Ohm | 83.30 ps | 590.99 mOhm | 0.00 - 1.71 pF | 3.93 nH |
There is a total of 269 rows of data for this one trace. There are 15 rows labeled "Path..." with the rest labeled "Seg...".
I already determined the "Seg-1", "Seg-2", etc. refer to portions of the "Path-" part of the trace listed above these. The path name, such as the "Path-U2(P3)-U1(AK25)" and "Path-U2(P3)-U3(P3)" in this example, appear to be the start and end pins of a portion of the trace.
Summing the length column and dividing by 2 to account for the duplicate lengths (paths + segments), then converting from mils to mm by multiplying by the conversion factor 0.0254 mm / 1 mil, I obtained 492.99 mm, which is much longer than 78.668 mm from the ULP. Deleting the path values and summing just the segments (without dividing by 2) gives the same length. Could you help with this discrepancy?
The data format conversion of stripping out the "mil" text and converting to a number is a nuisance. However, keep in mind that if analyzing a bus, there may be over a hundred signals that need data format conversion, not to mention summing and collating.
Gary
