Service Utility Not Responding
RCBakerBorn
RCBakerBorn
I tried to run a Repair Fusion 360 Electronics from the Service Utility Menu and it is not responding.
What gives? I can't open Fusion 360 Electronics, I can't repair Fusion 360 Electronics.
I paid for Fusion 360 electronics but can't use it.
This cloud based version sounds like a great idea, until you can't access it as readily as a downloadable software version.
The free version of Eagle was better than this as well.
I am frustrated.
Please help to restore my confidence in this expenditure or it will no longer be an expense.
I have attached a log file to assist in resolving this issue.
Thank you.
jorge_garcia
Hi @RCBakerBorn,
I hope you're doing well. My colleague is suggesting that you follow the procedure in this article
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-do-a-clean-...
In the meantime, I'll make a ticket with your logs. Is there anything special or unique about you computer setup?
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
