Selecting multiple components on a single layer
markgEVY95
markgEVY95
In Eagle, when I wanted to select multiple components on the top layer only, I would turn off the bOrigin layer before making my selection using the 'group' command. Having the bOrigin layer off, ensured that components on the bottom layer would not be selected even when enclosed with the grouping rectangle.
How do accomplish this in Fusion Electronics?
jorge_garcia
Hi @markgEVY95,
I hope you're doing well. For this, use the selection Filter make sure Components are one of your selectable types (your only one if you wish to select components) and that the layer is set to top. This will allow you to only select components on the top layer.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
