Schematic color scheme
ruben.crispino
ruben.crispino
Is there a way to change schematic color scheme from the Eagle scheme to Fusion360 electronics and vice versa?
m.neujahr_at_moe
Hello @ruben.crispino ,
yes, there is:
  • Profile -> Prefereces -> Electronics:
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
ruben.crispino
That setting enables the possibility to change between Light and Dark but not from the eagle color scheme to the default Fusion360. Is there something else I am missing?
ruben.crispino
jorge_garcia
Hi @ruben.crispino,
I hope you're doing well. By default, we are now shipping with the old EAGLE colors if I remember correctly. With that said if that's not what you are seeing you can grab the old defaultcolors.scr from your EAGLE installation and run it in Fusion 360. That will get you the colors you want.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
ruben.crispino
Thanks Jorge!
I actually find the way to use the old EAGLE colors (which was not the default in my case) just today but was wondering if there was a setting to revert back to the Fusion360 colors (orange components just to be clear)
jorge_garcia
Hi @ruben.crispino,
I hope you're doing well. If you go into Fusion 360 > Preferences > Electronics > Color there is a button that says reset to default colors. Click it and that should get you the colors back. You can always change the colors to whatever palette you prefer.
Best Regards,
Jorge Garcia
