Rotate Groups of Wires
jss.mlls
jss.mlls
I have these coils of wires in my PCB:
I would like to rotate these wires about the center of the circular cutout (ideally keeping their net names). Any ideas on how I can do this? The simple rotation command does not work.
Jesse
jorge_garcia
Hi @jss.mlls,
I hope you're doing well. You want to do a group rotate to achieve what you want. Here's the procedure.
1) Make a selection that contains all of the coils
2) Activate the rotate command
3) Hold ctrl and then right-click on the point you want to be the axis of rotation.
Voila! If you want to be specific about the axis of rotation then after step 2 you  can type the specific point in the CLI with the following syntax. (> x-coord y-coord) press enter.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
jss.mlls
Thanks Jorge, that worked great.
