Restore library that was removed using "Remove from view"
cgallant333
cgallant333
I accidentally removed a library from view. I can find it by searching the files in the data panel and it's, of course, in the schematics that use it. Is there any way to get it back in the list of Fusion Team libraries?
jorge_garcia
Hi @cgallant333,
I hope you're doing well. Go into the library manager, from there you can put it back into use.
In the lib manager, search for the library, and then click the button on the right to put it in use. It will be blue if it is in use.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
cgallant333
I wish it were as easy as that. When I clicked remove it from view, it disappeared entirely. It don't just gray out and switch the "In use" toggle from gray to blue.  Maybe I am misunderstanding you, but it's as though I deleted the library.
Thanks.
P.S. Your YouTube videos are A++
Taylor.Chris
"Remove from view" will delete the library from your manager.  Use the import button in the top right of the library manager to get it back.
