Recurring error in Fusion for missing Eagle libraries
rj_duran
rj_duran
I think this is the right place to report an issue. Anyway, I recently ran into an error in Fusion 360 that had to do with Eagle libraries.
Version: 2.0.9144
Active Plan: Fusion 360, Student
macOS 10.15.2
Issue: When I close my laptop running Fusion 360 then reopen it at a later time, I would get a series of errors saying that Eagle library files are missing. The only option at first was to force quit fusion and not deal with the error. But I would lose any unsaved work. I'm not sure why these files are even being loaded or used when I'm not using Eagle for the designs I have open.
Error message:
Failed to open '/Users/username/Library/Application Support/Eagle/lbr/adsk.eagle_library_179/con-phoenix-mkds_5.lbr'.
Background: I had to recently uninstall Fusion 360 manually and reinstall. In the process library files must have been deleted in the directory above.. I think. But not sure. Once I first encountered the error, I tried to update my install of Eagle to find it didn't not resolve the issue.
To resolve the issue I did the following:
1. Opened Eagle
2. Made a new schematic
3. Opened the library manager
4. Clicked the Available tab.
5. Clicked "Install Bundled Libraries"
6. Went back to fusion to see the errors gone.
When I looked in the /Users/username/Library/Application Support/Eagle/lbr folder I found it installed all the missing libraries.
References
  • bug
christopher2KLSVU
I have reported similar issue- kind of missing electron/neutron files. Have you had similar errors?
However I have never hibernate computer when fusion was opened. I always closing fusion before going to hibernate.
MichaelBmsi
This is clearly a bug with Fusion 360. Your workaround fixed the problem for the moment, but the real problem is that Fusion 360 is looking for all the bundled Eagle libraries when it wakes up. I reported this to customer support and hopefully it will be fixed. (Fusion 360 and Eagle standalone paid versions running on Dell XPS laptop with Win 10)
AlinaPeng
Hi @rj_duran
Sorry to hear that you're facing this issue.
I replicated the problem and escalated it to our developer team. We will try our best to fix it as soon as possible.
I will let you know once we have a fix for that.
Please accept our apologies for the inconvenience you're experiencing! Thank you very much for reporting this to us!
Best Regards,
Alina
Alina Peng
SQA Engineer
AlinaPeng
Hi @rj.duran
Hope you are doing well!
We have a good news to share with you that we have put a fix in today's latest update of Fusion 360 (version 2.0.9439).
Could you please have a double check to see if it works for you or not?
Thank you very much for your reporting.
Please feel free to let us know if need our further assistant.
Alina
Alina Peng
SQA Engineer
