Python scripting in Fusion 360 ECAD
dan.hanes
dan.hanes
Hello, I realize that F360 ECAD has the ULP scripting capability inherited from Eagle, but it would be far easier to use and more powerful if the API was transitioned to Python and incorporated into the F360 object model.  I know it takes time to do amazing things, but is this capability in the works?  If so, is there a timeline?  Thanks,
jorge_garcia
Hi @dan.hanes ,
It is being worked on, however I don't have a timeline for when it will be available. This is something I personally look forward to.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
engineeringNCMXB
@jorge_garciaWith that in mind.....is the file outputs for existing ULP's able to output to my local machine?
I have a few custom ULP's that I rely on to tie Eagle to my operations and manufacturing systems - are these going to work in Fusion360 with minimal changes?
Carlos Acosta
Factory400 - YouTube|Instagram
jorge_garcia
Hi @engineeringNCMXB ,
I hope you're doing well. They should work without much modification. If you look in the Documents Folder on your machine you'll find a Fusion 360 folder where you could have files sent to. Another option is to display any scripts before running them like we do with the import-dxf.ulp .
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
engineeringNCMXB
The ULP works but goes to this folder buried deep in the bowels of my system.....I don't see anything in the Documents folder.
Carlos Acosta
jorge_garcia
That's because the ULP assumes the files should be created in the same directory where the project is, so it creates it where the local project is cached. You could modify the ULP to ask you where to send the file, that would be the only modification to make. That way it doesn't default to this deep directory. ULPs can implement file open dialogs to get path information.
That's what you would have to do.
Best Regards,
Jorge Garcia
engineeringNCMXB
Excellent, sorted that one out. Thanks @jorge_garcia
Carlos Acosta
