Python cx_Freeze error when Fusion 360 Electronics exits
anthonyEX9NB
anthonyEX9NB
I get a python cx_Freeze error when I exit from Fusion 360 Electronics. Here's a screen cap of the error:
The autodesk assistant says this happens with a corrupted or conflicting Fusion installation, and the fix is to uninstall Fusion and then re-install it.
It appears that I can't uninstall Fusion using the Service Utility because I get the cx_Freeze error again. When I click the OK button, the error window goes away but nothing further happens.
What is wrong, and how do I fix it?
jorge_garcia
Hello @anthonyEX9NB ,
I hope you're doing well. Try uninstalling through Windows Add/Remove programs. I think a full re-install is needed here.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
anthonyEX9NB
Hi Jorge. The problem is now resolved but I don't know how. First, I noticed that I had python 3.12 installed on my computer and the cx_Freeze error was referencing python 3.14, so I updated python on my computer. But before I completed the update, out IT person said he "did some stuff" which maybe granted permission for some part of the error-causing process to run. And now I no longer get that cx_Freeze error when Fusion exits. Thanks.
