Push to 3d with problems
mario.brizida
Message 1 of 1
mario.brizida
In some pcb's when I make Push to 3d, I have problems with the holes. They give an error, yet the hole is correctly represented:
All the holes you see on the pcb are signed with error and you can see also the error detail.
I rechecked the pcb drawing (on Fusion Electronics), and everything is ok.
I had a pcb with a similar problem, but the holes were dupicated in the layout. I corrected them, and 3d got ok.
In this case I don't have duplication of holes, so I don't know what to do. What is the meaning of  'Please check inputs'?
I want to take the opportunity also to reenforce the suggestion made by several users  that, as in "old" Eagle we should be able to have our files in a local disk to avoid the problems we experienced caused by your servers that became offline or  anything else. I also suggest  the implementation of the possibility of edition of the parameters of silkscreen on pcb stack definition.
Thank you,
Thank you,
Thank you,
Replies (0)
