I'm using Electronics Design to create PCB's. I start with a Design file that has a sketch of the board which is offset from the origin and then use Create Associative PCB to push it to the Electronics Design to orient and specify the shape of the PCB. I added the electronics to the PCB, and then included it in another Design file used to build components that I 3D print to cover the board. All was good.
I recently discovered that I had an issue with a component that I created, so I updated the component and brought it into the electronics design. The component required rerouting the board, but there were no other mechanical changes. When I Pushed to 3D PCB, the pcb orientation was changed (rotated in one axis) and the offset was also apparently changed such that when I updated my printer Design, the board came in rotated and offset, which completely broke that design file.
I have had this problem before, but I'm finally frustrated enough to try to fix it. Any help is appreciated. If you need files, please let me know how to provide them.
Thanks.
