Push to 2D PCB
What does this command make?
I have a 3d PCB I tried to modify its board outline in 3D. I just made a circle in the PCB center and then I thought When I push it from 3D to 2D, in 2D editor I will have a hole. I t was done on the board outline sketch. This does not work.
Another method there is direct command in 3D, PCB modify a way to add a Hole, fine I defined a diameter and it is visible in 3D view , but When I do Push to 2D, it does not work. 2D board is not modified I thought it can transfer it to the dimension layer, what defines the board outline. But not.
Does this work ???
