Push from 3d PCB to 2d is not working
- Mute
- Permalink
- Report
Here is my problem. I edit a 3d model that contains the PCB with the Edit in Place feature. I then exit Edit in Place and save the assembly, I can see that the parent model of the 3d pcb is updated. (I discovered that that model has to be closed for this to work. I find this an major inconvenience.) I then open the PCB parent model and push it to the 2d PCB. This is does not work. The 2d pcb is not updated and I have a banner that says " The 2d and 3d PCB documents are out of sync." Which I cannot clear.
There is one more odd thing that I believe is related and that is in the 3d PCB model that I am editing when I move a component the pads don't move with it and when I try to select the pads that I intend to move all the pads are selected. This is where I believe the issue is.
Thanks for the help,
-Mike
