Printing Schematic produces rubbish
Rollmop
Rollmop
I am trying to print a schematic to PDF, but all the Names, values and labels come out as Gobbleygok (Rubbish).
What's the fix is there another way to export the schematic for printing?
jorge_garcia
Hello @Rollmop ,
I hope you're doing well. The best you can do if the normal printer isn't looking right is to try printing to PDF and then print from your PDF reader. Most of the time that works. Make sure you use the Print to File (PDF) option and not some other PDF driver you may have on your system.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Rollmop
Yes print to file seems to work thanks
Best Regards Simon
