pour not updated in 3d pcb when via moved
john.finleyZKHPN
john.finleyZKHPN
Hello! I figured I'd post this to see if it's known, since it's easy to reproduce. I can't find it in the forums anywhere but might have missed it. I'm a free (hobby) user, so prioritize accordingly :).
I have a board with a ground plane (pour) on the bottom. A signal routes from the top through a via, a short distance on the bottom, then back to the top. I generate a 3d pcb and it looks good. I go back to the pcb and move one of the vias. Push back to the 3d pcb, and the pour has not updated correctly.
To reproduce:
Create a new design
New schematic
Put a resistor on the schematic
Short the resistor on the schematic
Switch to pcb
Create a pour on bottom under the resistor
On the top, wire from one lead, drop a via (through the pour), a bit on the bottom, via, back to other lead on top
Push to 3d pcb
Looks good!
Back to 2d pcb
Move one of the vias a little bit
Push to 3d pcb
Bottom looks funky!
I can post files, but it's trivial to reproduce. Last picture below is after moving a via.
Workaround is to break link to 3d pcb, then push again; it looks correct after that.
As I mentioned, workaround is fine for me, but I thought the simplicity of reproduction was worth posting. Or I'm doing something odd, which is a specialty of mine.
panpan_fan
Hi @john.finleyZKHPN
I hope you are doing well!
For this issue, it has been fixed by the develop team.
I will keep you updated when we release the fixing.
Panpan Fan
panpan_fan
Today we release Fusion 360 V2.0.15022.
This issue should be fixed now.
Please update Fusion 360 and try it again, thanks!
Panpan Fan
john.finleyZKHPN
Neat! I let it update, then tried playing around with the simple test, and it works as expected. I'll be getting back to my more complicated (but still relatively simple) board next week, but it looks good. Thanks for the update.
