possible to move layer to another layer or re-order in the stack?
eric_engineer
eric_engineer
Is it possible to move one layer to another layer?  I routed a bunch of things on layer 2 that I'd rather have on layer 3.
Thank you
m.neujahr_at_moe
Hello @eric_engineer ,
can you try this workflow:
  1. In the layer-menu acitvate only the layer you want to change
  2. Make a "group" over all
  3. Use "change" - "layer" to the new layer
  4. "CTRL" + right-click
  5. This is the result:
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
jorge_garcia
Hi @eric_engineer ,
In addition to @m.neujahr_at_moe excellent suggestion, you can also try the copy-wire-to-any-layer.ulp that comes with Fusion 360.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
eric_engineer
So this just pops an error: "select valid layer"
jorge_garcia
Hi @eric_engineer ,
I hope you're doing well. This is an old ULP, the trick to it is to type in the layer numbers at the bottom of the two comboboxes. What you click in the comboboxes  actually does nothing, you have to type in the layer numbers in the fields at the bottom.
Best Regards,
Jorge Garcia
