Persistant groups
Persistant groups
TimZT
Message 1 of 8
Persistant groups
TimZT
Hello forum,
Anytime I select a group for some operation I don't seem to be able to de-select the group after I have finished.  In Eagle any other operation on another part of the circuit would de-select the group and the parts would again be free to move independently, in Fusion I have tried Info or Show and clicking on a random part but next time the schematic is selected the group is back - across all sheets covered by the group.  It certainly would help me out a lot if someone could advise a repeatable workaround to release the parts from that group.
Oh and I did try to deselect a group using the inspector once and managed to delete all the part attributes on a 300+ part PCB just before submitting it 🙄
I am sure this is not a bug just my misunderstanding of how group select is handled - thank you
Replies (7)
Message 2 of 8
jorge_garcia
Hi @TimZT ,
I hope you're doing well. The use of the term persistent gives me pause because there is an actual feature in Electronics called "Persistent Groups". Those behave different than a normal selection.
Generally speaking, pressing ESC will clear the selection allowing you to select something else.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 3 of 8
TimZT
Hello Jorge,
Thank you for replying to my post.  No, pressing ESC does not clear the selection.  Is it possibly a preferences setting?
Message 4 of 8
nnovotney
How about having a right click on the group outline called ungroup ?
It is nice to be able to do some other operations and then shortly thereafter go back to the group (for moving, deleting, whatever), without losing the grouping (creating the group may be a long process: if you clicked 20 components to add to a circled group,  you don't want to lose all those clicks)
Message 5 of 8
TimZT
I have a workaround for now, I just select another group of say, 2 components and it releases the original group.
Message 6 of 8
jorge_garcia
Hey @TimZT ,
If you are able please make a quick screen recording of your workflow. Something in the description is not adding up for me.
Thank you in advanced.
Best Regards,
​Jorge Garcia
Message 7 of 8
TimZT
Hello Jorge, I can not do that at this time.  Please can you advise, if I use the select tool to create a group, what is the correct procedure to de-select the group and release the parts?  Please do not advise pressing ESC as this has no effect.
Also, in preferences I have Group Command Default On, deselected.
Message 8 of 8
jorge_garcia
Hi @TimZT ,
See the attached video. This is how normal selection works, it gets cleared by pressing ESC until the group deselects. Is this the type of selection you are dealing with?
​Jorge Garcia
