PCB Thickness is incorrect based on the Eagle DRC Layer settings
websterdav
Observer Observer
Message 1 of 1
websterdav
Observer
Observer
the Fusion PCB Thickness is incorrect based on the Eagle DRC Layer settings.  I have followed the recommended workaround (setting it to 2-Layer and then back again to 8-Layer and Pushing again, and updating Fusion to the newest revision).  That did not work and the board is 5.534mm instead of the DRC thickness of 1.6mm.
The previous versions of the board worked fine (before May 2022).  The board DRC settings have not changed.
Does anyone know a fix?  Seems like some bug in a release that happened sometime in May 2022.
Replies (0)
