PCB outline derived from case improved workflow
Hi all,
Just wanted to share a workflow that I figured out today, that allows a 3D PCB outline to be linked to the case/housing/assembly that it sits in, without using the broken "Derive PCB from Sketch" feature.
The problem with "Derive PCB from Sketch" is while it allows a 3D PCB to update its shape based on a sketch in the case assembly, it does not allow that PCB to be included in the same assembly - trying to do so errors out complaining about "circular references".
The way I'm about to describe doesn't seem to have this problem. Here goes...
- Create a model for your case/housing/assembly and save it
- Click "Create" -> "Create 3D PCB" (it doesn't matter which profile you choose so just pick one)
- Save the new 3D PCB, go back to your assembly and insert the PCB into the assembly
- Move the PCB to roughly where you want it
- Hover over the PCB in the component list and click on "edit in place"
- Double click on the "Outline" sketch in the PCB to edit it
- In the sketch editor, use project/include to associate the PCB outline to geometry from the assembly. For instance, I included the walls of the case into my sketch, then set a dimension of 5mm between the wall and the outline of my PCB.
- End sketch & end edit-in-place
- Now when I change the position of the wall in my assembly, the PCB outline is automatically updated to match!
- Associate the 3D sketch with a 2D sketch, electronics design and schematic
