PCB Design Variants
PCB Design Variants
joao.ricardo.silva.97
PCB Design Variants
Hi everyone.
I wold like to know if there are any plans to a better Variant management.
It's a bit annoying to have to write a command each time you want to select another Variant. Eagle has a dropdown to select the current Variant.
A cool feature cold be a detachable window like new "Layers" window where you can select your current Variant.
Another thing is the Populate menu. Fusion should have a better way to select if a component is populated or not, and even if you want to populate/unpopulate a selection, you have to run a script...
Thank you
jorge_garcia
Hi @joao.ricardo.silva.97 ,
Thank you for this recommendation, I'll make a note of the feature request to strengthen the UI for the Variants command.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
