Package Generator NOT available
"Package Generator" is not available, within "PCB Package" in "Package 3D" menus, nor within "shortcuts search" either.
File -> New Electronics Library -> Create New Package -> PCB Package -> ??
Looked everywhere and found no reference to this issue.
Help!!!
yiqiu.han
Hi, @Anonymous
Would you please go to the tools tab to check the running status of add-ins here?
Thanks!
Add-ins are running.
Is the Package Generator menu option, within the “PACKAGE 3D” menu (File->New Electronics Library->Create New Package->PCB Package), supposed to be an add-in?
yiqiu.han
Hi, @Anonymous
Yeah, package generator is an add-in developed by us.
Would you please share a screencast or screen capture with us to learn about the status?
My suggestion here is:
1. Stop PG add-in and then start it again
2. Try to use other scripts/add-ins to see if they can work normally
3. The worse way, re-install Fusion 360 maybe?
Anyway, let us know the detail status would be helpful to our investigation if above mentioned methods cannot make PG works normal again.
Yiqiu
Sorry, I didn't realize it was an ADD-IN.  Just activated it, within the ADD-INs and solved.
