Orphans not suppressed
dev2EP8UX
dev2EP8UX
Two nested GND polygons. Outer poly is rank 3, inner poly is rank 1. Both have Orphans disabled. Still, the orphans show:
In the the Eagle design of the same board, the orphans don't show.
Is this intended behaviour, maybe a new option I am missing?
jorge_garcia
Hi @dev2EP8UX,
Hmmm.... That shouldn't be happening. So just to double check make sure you don't have any additional overlapping polygons. For the orphans to disappear all of the polygons that are overlapping need to have orphans off.
If after checking the above, you still see the orphans then I'll need a file to share with the developers for review.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
dev2EP8UX
Jorge, thanks. There are no additional overlapping polygons there, only the two GND polygons. I'll see if i can remove some of the design so i can share it with you.
