Oddities entering position values
This is a change from a week or two ago. When my grid is set to inches, the input boxes for position of an element are now very picky about how they'll accept entries. I can't start any entry with something that isn't a number. So I can't type ".5" I have to type "0.5". That alone isn't terrible, but it means you can't type in negative values directly, you have to enter a number, then arrow back and add the negative. It also won't let me fully delete a value before entering a new one, it refuses to delete the first number until I input another and then again arrow over and delete the first one.
With units set to mils I see the same issue with it not accepting a negative symbol or decimal before a number is entered, but obviously you don't use a decimal as often in that unit system.
This was not a problem previously, so I'm not sure what changed. I do not see this same issue in the other fusion workspaces, only electronics.
