Not solder resist varnish
hudak.zoltan
hudak.zoltan
Dear FUSION team,
  1. I would like to ask, whether there is a possibility in the FUSION 360 PCB design, to solve that some PCB traces and polygons don’t have solder resist varnish?( We would like some of traces soldering because they carries higher current.)
  2. Is there possibility to designing design blocks? (As it was in former Eagle?)
Thank you for your advance!
Best regards,
Zoltán Hudák
jorge_garcia
Hello @hudak.zoltan ,
I hope you're doing well. Design blocks have not made it into Fusion 360 yet but we are working on it.
It is possible to expose the copper of traces and polygons, just make sure to trace over those features using the tStop(for top) and bStop(for bottom) layers. Anything those layers touch will remain exposed copper and solderable.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
