No "GO" button anymore!
Tbaker25
Tbaker25
Autorouter- when selecting aiwires to route, you cannot select "GO" to continue routing! This is a pretty big problem. It was always there in Eagle, but the traffic light icon is completely gone! How can I route only a select set of signals without naming all of them in the command line?
Tom
jorge_garcia
Hi @Tbaker25 ,
I hope you're doing well. The key here is to press enter twice once you have selected your airwires. That will do the same as the GO button.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Tbaker25
Thank you for the workaround. Definitely needs a UI fix on this one. 🙂
Tom
