some of you may already have mentioned that when you delete a net class in EAGLE or Fusion, the other net classes are not automatically renumbered, as you can see here, which is an example in EAGLE 9.6.2:
In Fusion360, the numbers on the top were changed, as you can see here, which is the same project:
Now the problem is, that the new assignments are faulty. When I edit the 4-->4 assignment which I expect would be L_New --> L_New, in reality it changed the L_New --> PE assignment. I also saw this behaviour in the layout.
I think this is very problematic because there might be projects where it does not get noticed directly.
I think the best you can do until this gets fixed is to remove all classes and add them again manually so that the numbering is correct.
I added a test brd file with the netclasses seen above.
