Hi @grahamUTKMN,
I hope you're doing well. You can insert designblocks by just going to the place section of the top menu
Designblocks have to be inserted into a design. They are not a design by themselves.
THe autorouter will definitely make the connections, I'll leave it to you to judge if the result is worthwhile for you.
So the easiest way to bring in your libraries into Fusion will depend on what type of libs you are using. If you have never used managed libraries then the easiest way to use them in Fusion is to upload them. This will create a cloud copy of your libs that are completely separate for your original libs. If you want to keep a link between Fusion and EAGLE then you'll have to use managed libs. I cover transitioning EAGLE data into Fusion in this video series.
https://www.youtube.com/playlist?list=PLmA_xUT-8UlL5wTsDLkXtj_nBwojmRf5b
I have to update video 4 since we have a much better method of doing what's show in that video now.
In the 2D PCB you'll find the DRC in the VALIDATE sub menu at the top.
You can find the Netclasses in the VALIDATE sub menu as well.
You can always type CLASS and DRC in the command line and press enter to access them.
It's interesting that your airwires have a different color by default they a still supposed to be yellow. You can change the layer colors in the display layers panel. Select the Unrouted layer and then in the details at the bottom you can change the layer color.
Ratsnest in Fusion is always active and runs automatically so you don't have run it manually anymore. You can still force it by typing RATSNEST in the CLI and press enter. I don't think this is necessary anymore but the option is there.
In the polygon command of the main menu you'll find the option to hide the polygon pours. The outline always stays behind to let you know how the polygon had filled. If you don't like it, those outlines will disappear as soon as you route or move something.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Product Support Specialist for Fusion 360 and EAGLE
