Move Group between sheets hides attributes
hh68Z3D
hh68Z3D
Why are all attributes hidden after I move a group from one sheet to another? How do I bring them back in a quick way?
Best regards
Haris Hujic
jorge_garcia
Hi @hh68Z3D,
I hope this message finds you well. I've pinged the developers on this. In the meantime, I have a few questions:
Does that only happen with names/values (default attributes) or also happens with user defined attributes?
Click the Attribute command and then click on any part in the group, does that still show “both” in Visible property?
Does it come back when switching to different sheet and back to sheet where you moved the group?
Let me know if you continue to run into issues.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
