Request: For designs using Modules, allow change of Refdes separator character ":" to "_" (or almost anything else).
Reason: Some PLM Software take the ":" separator as indicating a range of reference designators ... ex. C3:C6 would mean C3, C4, C5, C6 and it would expect a QTY of 4.
With the current separator the PLM checking is flagging every row of the BOM with a module REFDES as having issues. ie. REFDES does not match QTY, or the lower prefix doesn't match the higher prefix.
Image below has 3 examples:
1) C3:C6 with qty 4 and no errors
2) a module named MYMODULE with instance 1 and a single resistor "R4" in that instance. Unfortunately the checking thinks that either the lower or upper prefixes are incorrect and the Qty of REFDES items doesn't match the actual quantity.
3) same MYMODULE example but with an "_" instead of ":"
Best Regards,
-- Glenn
