Maximum dimensions for pcb for free users
martinyoung1
martinyoung1
Hi
Quite simple really what is the maximum size for a PCB if you have a personal account,
i have just learnt the basics of PCB design to go with my project and it looks like I'm now stuck.
Thanks Martin.
jorge_garcia
Hi @martinyoung1 ,
The size limits for the personal Fusion entitlement is a max area (L x W) of 80cm^2 with the bottom left corner of the board located at the origin.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
martinyoung1
So can a make a circular PCB with a 50mm radius 7853mm2
jorge_garcia
Hi @martinyoung1,
I hope you're doing well. That may not work because the square envelope that encloses the circle would be 100mm x 100mm. The measurement is based on copper so depending on how you place your components you may be able to still make the circular PCB.
Let me know if that's clear.
Best Regards,
Jorge Garcia
martinyoung1
I have altered the sketch used to produce the pcb and added a couple of lines to the bottom left to allow me to place the origin off the board, then only selected the circular portion when producing the pcb, this seems to work as far as I now have a round pcb board in the electronics environment with the origin off the board to the lower left,
it is allowing me to place components anywhere on the board.
