material for use in cooling simulation
eric_engineer
eric_engineer
Hi, I'm working on an electronic cooling project in fusion 360. Very simple just an IC, heatsink, and maybe a fan.  I can never figure out the right material to choose for the IC (which is the heat load). It's a normal plastic encapsulated package, the standard black ICs, sometimes called "Epoxy Mold Compound"  Any idea what the right thing to pick here is?
Thank you.
jorge_garcia
Hi @eric_engineer,
I've reached out to my e-cooling colleagues and they will correct me if I'm wrong here. By default there is an generic electronic component material. This is what you should use for IC bodies.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
eric_engineer
Okay, I think it is called "discrete component".  That took a while to find, the docs and videos on this feature are kind of scattered around.
Thank you.
igor.krolikowski8YYUQ
The most important would be to verify the thermal conductivity material properties: model vs reality.
Igor Krolikowski
Software Development Manager
Product Design & Manufacturing
Autodesk, Inc.
