Library structure with 3D packages
mattmoritz
mattmoritz
Hello electronic team,
i want to start in Fusion 360 electronics with new fresh team-libraries. I was working with Eagle the  last 20 years.
So without using the shared (linked) Library.io  working method, i placed a copy of my interesting library out of the library manager in an new library folder in Fusion 360.
The new team-library has the symbol and footprints but only a link to the 3D package model in Library.io.
With a double-click on the package icon, the dialog box appeard, with the info, that the referenced package is not
stored in Fusion Team. I can put a copy of the package to Fusion Team with a reference update.
It works well, but now i get new files in my libraries folder for each 3D package.
I can move them in a subfolder to clean up the main library folder, but in the end it is a bit annoying
to handle all the extra 3D package files.
Is there a way to integrate the 3D packages into the corresponding library ?
What is your recommendation for a new (team) library from the ground up with the 3D packages ?
(using some already created packages from the community in Library.io)
Thanks for your support.
Matt
jorge_garcia
Hi @mattmoritz ,
I hope you're doing well. I know exactly what you mean, this is currently the best way to work with libraries in Fusion 360. See this series for some helpful tips.
https://www.youtube.com/watch?v=xNIEXCimRSg
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
