Library package update sync issues
So I have been plagued with an issue since the v.2703.1.11 update. I filed a report form the app and left comments when I did a fresh install in attempt to fix. The AI assistant suggested that I post here for visibility, because this makes the time consuming task of ECAD library management exponentially more time consuming. When creating a new component, everything goes smooth and can attach the 3D package to the footprint no problem and it saves without issue and uploads to my hub. If I have to have to edit a footprint, I'll edit the package in case it needs to be repositioned and save the package. The blue progress bar goes across the bottom of the Content Manager tab and everything looks like the library is good to go, but when I save the library it says it has to wait for uploads to finish. The upload was finished lol. After digging around I noticed that the in the packages tab, the package I just updated is greyed out with the progress wheel spinning and spinning. This will go on indefinitely. I then have to force close the library without saving, because fusion won't let you save while it thinks an upload is still going on. Any work that was done prior to editing a package is lost if it wasn't saved first, which has been infuriating. I eventually noticed that when I reopened the library in the packages tab there is an option to update the package to the latest version. SO the package is obviously syncing to the hub just fine, but it's then not providing the correct response to the app so it knows it completed uploading the change.
I am using MacOS ARM64. I have also created a new account, which creates a new hub and the issue replicates. Steps to reproduce:
1. create a library
2. import a component
3. attach a package to the footprint
4. save and close the library
5. reopen that library
6. edit any package it that library and save it
