Library not updating pcb layout regardless to approach
Tiksom
Tiksom
Hi
I`m pulling my head as to unrelialbe way of editing the libriaries in F360 electronics.
No matter how many times i try to edit the pad spacing, the library pcb layout is ok, but when inserted to design the problem remains. I saved numerus times, renamed, deleted/added. This is just silly and I`m sure it`s not that complicated.
Video
https://screencast.autodesk.com/Embed/Timeline/acbf68c5-9d42-433e-a2f4-f55707567373
jorge_garcia
Hi @Tiksom ,
I hope you're doing well. You are getting bit by the annular ring settings(formerly known as restring). See this blog post for the full details
https://www.autodesk.com/products/fusion-360/blog/what-you-didnt-know-about-eagle-restring/
In short what's happening here, is that the default annular ring settings are causing your pads to swell a little and that creates the clearance violations you are seeing. Your part is made correctly in the library, so you don't have to look there.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
