January 2025 Update and Community bug fixes (ECAD)
jorge_garcia
Autodesk Autodesk
Message 1 of 1
jorge_garcia
Hello to the Fusion ECAD Community!
In anticipation of the January update going out next week, we've decided to do an early drop on the details of what community bugs have been addressed this time around! If you want to get an early jump on these fixes, you're more than welcome to apply for the Insider Program and get early access!
We greatly appreciate you taking time out of your busy schedule to notify us of the issues that you find in Fusion, and we would like to show that appreciation!
In an ongoing effort to increase our transparency as well as our communication with you, we're continuing with our initiative of calling out all the Forum Reported bug fixes that are included in each update. The list below comprises all the issues that have been raised by our engaged community. So, without further ado, here is what we're going to see in the January 2024 update (creator of forum thread and the thread itself, in no particular order):
ECAD
Special characters are now escaped properly in Active CAM job paths
@silvio3105
Polygon pours are now aware of via stitch areas with the same net and will not create orphans
@silvio3105
The power net check box will no longer create inconsistent designs
@cyberreefguru
Moving power nets between sheets will no longer cause inconsistency
@josh_l
Nonconvex polygons are now handled properly by DRC
@silvio3105
Special characters are now supported in scope names
@n.smithHJCP5
Mirrorable layers are now fully supported in CAM Processor
@warren_hawkins57R37
Decals are now properly visible on a 3D PCB
@kterryTYYYC
The display command can now properly call layer sets
@kerry.gerontianos
Align to Grid in Quick actions in the inspector is now functional
@nathan_langford6LLCW
DRC will now generate proper errors with Via stitching
@autodesk8LRWT
CAM processor now supports higher resolution image export
@_Marek
Autorouter now shows fewer dialogs before starting
@jbermingham
Just as in prior updates, this isn’t to suggest that those are the only fixes that we've included. The list above are the issues specific to the ECAD community; within this update our team has additionally found and fixed well over 100 different bugs and issues.
Still haven’t seen your issue on the list and wondering if/when it's going to get fixed? Don't hesitate to "bump" the original thread that you created, and I'll be happy to chase down the status of your issue!
Thanks for contributing to what makes the software truly great!
Click here to see patch notes from prior releases:
March ‘24
May ‘24
July ‘24
September ‘24
November ‘24
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Replies (0)
