Is there a general select point command?
eric_engineer
eric_engineer
For example I'm making a schematic title block. I choose the frame command and click on 0,0 to start.  I'd like to just type 11,7 to place the other side of my frame at 11" x 7" away.  Same for any placement command.
Thank you
jorge_garcia
Hi @eric_engineer,
I hope you're doing well. Basically, whatever object is floating on your mouse cursor you can always place precisely by clicking in the electronics command line and then typing in the point where you want to place it, here's the format
(x-coord y-coord)
then press enter.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
