Is old way to add pcb with eagle is removed?
I don't like how new pcb design bench works, and i don't want to redo the work.
I also could not find a way to the push and pull pcb design like old one.
is that removed or done differently?
jorge_garcia
Hi @Anonymous,
I hope you're doing well. The workflow with EAGLE has not been removed it's just temporarily broken. We are working to have that workflow restored as soon as possible.
In the meantime, workflow in Fusion Electronics is functional and should work. From the 2D PCB you can push to 3D PCB make changes there and then you can send those changes back to the 2D PCB.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
I am using fusion pcb for now.
same here.
the board outline can't be updated from fusion 360 cad to electronics.
Eagle one is just click "pull" and updated pcb outline and screw holes are updated.
