Insert DXF file to PCB issue
jonas.boeckler
jonas.boeckler
I think I have discovered a bug in the new import procedure for DXF and DWG files.
Since the April 2023 update it is possible to import DXF or DWG files with a new native import tool in the PCB workspace. Traditionally this was done using a script routine.
In the "open file" window i click on "Select from my computer..."
The "Select File" window allows you to select a .dxf or .dwg file from your computer, but the file endings of "supported files" drop down menu displays: (*.dxf,;*.dwg).
I think after the ending .dxf there is a comma too many.
That's why I can't select a .dxf file.
Is this only a Windows problem?
In the "What's new in Fusion 360 - April 2023" on YouTube, this feature is presented with macOS and it works there.
https://www.youtube.com/watch?v=1VfdOTTb4L0
@1:55 minutes
Regards
Jonas
HelenChen-ElectronicsQA
Hi @jonas.boeckler ,
Thank you very much for your feedback!
Good catch!
We just checked this issue and noticed it's reproducible in Deutch Fusion, but it's in English Fusion and other languages.
Before this issue is fixed, please kindly switch to English Fusion to insert DXF when needed.
So sorry for any inconvenience.
We will keep you be posted once this issue is fixed.
Hope you have a great day!
Best regards,
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
