How to import KiCAD projects into Fusion 360 or Eagle?
I'm looking to import our KiCAD Projects into Fusion 360 in order to utilize the electronics side of Fusion and optimize our workflow.
How do I import KiCAD files into Fusion 360 or Eagle? Can someone from Autodesk suggest a method or tool to import the KiCAD projects into Fusion 360 or Eagle?
Pieter.Jan.Van.de.Maele
Hi all,
A BETA version of our new KiCAD importer is now available through the insider program. The insider program gives you access to our next release (May) ahead of time so we can collect valuable feedback. It is compatible with the production version of Fusion.
Instructions on how to sign up for the insider program are here:
https://forums.autodesk.com/t5/fusion-electronics/become-an-autodesk-fusion-insider/td-p/10552765
Instructions on how to use the KiCAD importer will be available in the insider forum (Electronics section) once you sign up.
Pieter-Jan Van de Maele
Senior Engineering Manager, Fusion Electronics
FrankEagle
Has this feature been released?
I'm using the July 2024 update, but can't find it.
jorge_garcia
Hello @FrankEagle
The KiCAD importer was delayed that's why you are not seeing it in the July update. It should be out shortly in the next release barring any issues.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
FrankEagle
Thank you.
