How to fork a electronic design correct?
HarrySatt
HarrySatt
Hi
what I need to do is to end the electronic design at one point and quote it with finished. After that I would like to add a complete new design but do not want to start from scratch but keep on using the finished design for further enhancements to reach a new finished version and so on. If a design is manufactured it should be halted at that version and a completly new design should be started on the top of this outcome.
At the moment I use milestone for this but in fact it is not what I really want. If I f.e. design a test design and want to use it for starting point of more then one design than I run into this problem. How to disconnect correctly all the links in the design and how to copy to a really fresh location?
@RichardHammerl
@jorge_garcia
RichardHammerl
Hi @HarrySatt,
you could mark your finished design as a milestone, that's a good idea.
For continuing with a new project you could then just create a new electronics design, and then link to your existing schematic and board, BUT be sure to check the Create a copy option in the file dialog.
Best regards,
Richard Hammerl
HarrySatt
Sounds useful. Are there all links set to the new (copied) design so that I can rename the SCH, BRD the folder and generated 3D to other names and assemblies. Or do I have to change the links in assemblies to newly created 3D designs.
Regards, Harald
@RichardHammerl
jorge_garcia
Hi @HarrySatt ,
When you follow Richard's procedure, you get a completely separate copy so you don't have to worry about poluting the original design you copied from.
Hope this helps.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
