How to delete/remove Wire Stub all together
a_redoy
a_redoy
Hi everyone,
when I DRC check on my PCB Everytime it Shows Warnings about Wire Stub. It looks like small bubble of traces. I know this is not too much important but i want to make my design more clean.
At present i have to delete it one by one which is very time consuming. and sometime its quantity is huge.
so, i want to know that is there any technique or process to delete this Wire Stub all at a time?
or i have to delete this one by one like what i am doing this regularly.
Thanks.
jorge_garcia
Hello @a_redoy,
I hope you're doing well. There's no mechanism for automatically clearing the wire stubs. With that said, the best way to avoid wire stubs is to not create them in the first place. When manually routing make sure to always start and end at the center of a pad or via. Doing so will minimize the changes of creating a wire stub.
Looking at the images you have about 20, I know it's a pain but for now the best solution is to fix them manually.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
