How to add user defined layer pair 55 or 56 in CAM?
m.ensing2UAQJ
m.ensing2UAQJ
I created a new image output and can only select to layer 52 and from layer 100, but the layers in between appear not to be present? I would like to add layer 55, or 56 depending on top or bottom info.... what is the reason the layers do not show?
jorge_garcia
Hi @m.ensing2UAQJ,
I don't know if it was you but someone else reported this recently. I've filed a bug report for this, the CAM processor doesn't seem to be processing those layers correctly. I assume you were able add them in the 2D PCB editor.
I'll add your comments to the ticket for this issue, to see how quickly it can be prioritized.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
