How to add plated through holes and non-plated through holes larger than 0.1" to a footprint
yaqoubdesign
yaqoubdesign
I often have need to add plated through holes and NPTHs  with drill size > 0.1",  but fusion 360 electronics does not have that option when creating a footprint. Max is 0.1".   Same with NPTH.  Anyone know of a work-around?
jorge_garcia
Hi @yaqoubdesign ,
I hope you're doing well. You can actually type whatever drill size you need in the drill field of the hole o via command. Type in the value and press enter then you'll be able to place drills of that size.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
yaqoubdesign
Thanks !
