How to add fields such as Manufacturer Part Number to Bom
gtoner2506
gtoner2506
I have made a new resistor library in fusion electronics to which I have added a 0 ohm resistor. I have added attributes to this part in the library  such as Manufacturers part number, cost, vendor and then placed it in a schematic. When I run the BOM command in schematic (under DOCUMENT | OUTPUT) I just get the usual five fields - part, value, etc. How can I add the additional attributes I have created in the library part to the BOM report so as to create a BOM which  contains usable information? Total newbee here, coming from Altium for ECAD but a competent Fusion 360 mechanical user.
ritste20
Make sure you have list attributes checked in the document output dialog box. See pic below
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
gtoner2506
Seems I wasn't saving the library and then using LIBRARY|UPDATE DESIGN FROM LIBRARY. Now the attributes appear in the BOM.
Thanks for the quick reply!
